SVTJON87
obviously I'm having problems getting the lower ball joint out of the hub/knuckle.
after searching i have employed a crow bar. then a long pry bar about 4 feet long (jack handle). i also tired using an air chisel to help open up the hub but that did not work. i just picked up a pickle fork ( ball joint separator).
i was wondering if there was something i missed. i know this is not a simple unbolt and remove. thanks everyone.
i am going to go stand on the long pry bar.
i should also add that yes i am using a jack to lift up the hub to give the ball joint room to fall out.
