You'd better hope not. Throwing a new IMRC on is a lot easier. Here are the pinouts to test with a multimeter.
Has anyone priced an IMRC lately????? Unless someone has personal access to the manufacture,I had that info long ago unfortunately crash Hard Drives later.
Ford wants 5x-6x times what it was originally! Known as actuator Jenkins price only $976.49 and only $731.59 SVT. Didn't know there was a difference?
I've been ,having this trouble, just hours ago dead no explosion when wide open. HOWEVER, using scan toll to operate the IMRC works fine????? There was a P1519 (bank 1) stuck closed which is an error cause there is nothing in place to tell the PCM bank 1 or 2. correct me if I'm wrong but the circuit to do this is inside the IMRC. At least on my Mistake.
It's done this 3 time this month and get home get the laptop out, using OBD-2.com Alex Pepel soft and interface. Go to Ford Test/enhanced "output test for low & high fan ON, ALL off or and all ON except fans and injectors. 4 separate tests.
There are no tests on other sensors and test according to the Ford CD is integrite of the mechanical linkage and of the electrical ie connector to the IMRC.
I just remembered one thing I found was loose ground (screws on IMRC's ckt board) but you need scan tool to tell the PCM to operate IMRC
Now to the testing. Later
