There was a honed one on taurusclub.com for sale when I was trying to sell my powder coated one.
Would depend on the size of an EH ST220 port and the size of a plastic LIM but I don't see that being possible :shrug:Why dint you just port match the plastic lower to the st220?
I live less than an hour from EH.
I'm REALLY thinking of taking in the ST220 in my basement for this GB.
The question then becomes, is there an aluminum 3L oval port LIM to have ported to match an EH ST220 UIM?
-J
IIRC the st220 LIM was alum. Why not shave away the plastic lim..to make it larger? :shrug:
I think this obsession with huge amounts of CFMs...Is not right. Volumetric efficiency is going right out the window.
i finally agree with you!
you guys are missing the point in why the 3L split port manifold is NOT as good as the SVT manifold. its runners are not equal length.
That 3L UIM EX-honed and the fake runner splits they added were removed. That would make it a great substitute for a st220 uim.
IDK how much material there is to work with on the UIM, but you might be able to taper it going to the split ports, instead of having just a flat bar between them.duh..i forgot the bolt patterns are different :blackeye:
after Joe Powder coated let me tell you it makes me wet in the pants...
Why's everyone obsessed with rpms? Look at the lemans corvette c6r it goes 200 mph makes over 500 hp an shifts a 4700 rpms
also, there is more HP potential at a higher RPM than a lower RPM.large displacment V8 =/= small high reving V6
apples to oranges. large V8's can't typically rev as high as a smaller V6.
so are you gonna go public with what happened to your current motor? i heard it started consuming tons of oil or something? our dyno battles are on hold? wtf!
