DyComet
Full payment sent.
Has anyone considered that the aluminum will soak up heat and release it into the "filter zone." Most K&N heatshields are made of plastic for this very reason.
Pudmunkie,
With this Heat shield, has the design been created as an attempt to seal off the heat w/ the hood liner in or w/ the hood liner removed?
I just recently removed my liner and the rubber hood seal in the rear (by the cabin filter) to get more air flow and to reduce under hood temps. I actually can see a difference on the temp gauge as before doing this the needle was constantly in the middle of the temp gauge and now it is constantly slightly lower than the middle. Definitely noticeable on the gauge at least.
Anyway back on topic....what would be the better thing to do w/ this heat shield. Leave the liner out or put it back.
Thanks
