GB: TZT Performance rear toe arms
Status
Not open for further replies.
striker2
Official CEG Vendor
Arvada, CO
There is NO warranty expressed or implied on these endlinks. IF you should have a problem with one you MUST send the entire link back to me for an inspection. If after an inspection the problem is found to be a manufacturing defect I will then fix/replace the problem at no cost to you. If however the problem is found to be from installation error or any kind of abuse (that includes road hazards) I will give you the available options to fix/replace the link at the buyers cost.
You all know how this works and what these replace. these will use rod ends at both ends of the tube. the reason i decided that is because i had some of the bushed ends come with bad threads which tears up the threads in the tube. obviously thats no good.
the tubes are gold anodized aluminum and the rod ends are 2 piece high misalignment ends with a teflon lined alloy steel body. they are rated at over 24,000lbs static radial load. each arm is LH and RH threaded and has a wrench flat on the LH threaded end to make adjustment quick and easy.
there will be 2 different pricing options for these. option 1 comes with a pair of arms, and replacement bolts and washers for the outer (knuckle side) connections. this option allows the use of the factory adjustment bolts as well as the arms. option 2 is a little more expensive but comes with replacement bolts/washers/nuts for the inner connections as well. the second option would replace the factory adjustment hardware so toe adjustments would only be made using the toe arms. all hardware for either option is zinc coated and metric class 10.9 (about grade 8)
Cost
Option 1: $165 + shipping
Option 2: $180 + shipping
Shipping
Shipping to the Lower 48 will be $20 via UPS (USPS or FedEx on request)
Shipping to Canada will be $45 via USPS
anyone outside the lower 48 or Canada needs to request a shipping quote first. I can also combine shipping if you get endlinks as well, it will be just the cost of the shipping for the toe arms.
Payment
Payments need to be sent to sales at tztperformance dot com and must include your screen name, real name, shipping address, what forum you are from (CEG/NECO), and what you are purchasing (toe arms, endlinks, both, and which option for the toe arms).
Pictures
they will all look like the bottom arm in the following pictures, with a rod end (heim) at both ends.
stock arm vs new arms.
new hardware is zinc plated class 10.9. Option 1 only comes with the lower left bolt, Option 2 comes with both bolts.
Installed pic of both the arms and rear endlinks.
Current list
1. Stuart-Grant - Option 2 (NECO) PAID
2. Necronommicon Option 2 (CEG) PAID
3. iceberg65- Option 1 (NECO)
4. 1Sicgt Option 1 (CEG)
5. SVT Doood Option 2 (CEG)
6. Southsiderida90 Option 2 (CEG)
7. hopeless02 Option 2 (NECO) PAID
8. DonKingKong Option 1 (CEG) PAID
9. speed_cat Option 2 (CEG) PAID
10. cwit703 Option 2 (CEG)
11. JRoX85 Option 2 (CEG)
Current list
7.
8.
9.
7. DonKingKong (CEG)
8.
9.
8.Speed_cat option 1 (CEG)
9.
Other than what you have mentioned above, is there any more benefits from choosing
option 2?
9.
Other than what you have mentioned above, is there any more benefits from choosing option 2?
Ready for money?? Sorry, just getting antsy to get all this new goodness on the 'tour!
Im working on turning this into a real business and setting up a proper email and paypal accounts for said business. as soon as thats done I will make a post here and update the payment and shipping info. should be sometime this week if all goes according to plan.
Current list
8. DonKingKong Option ? (CEG)
9. speed_cat Option 1 (CEG)
PM sent for shipping qoute.
Current list
what kinda shipping time frame is ther from payed to delivery?
Status
