MLuko
Pope..
Demon is running mid 13's to boot....IIRC 13.47 or so.
thrust
why wont the driveshaftshop axles hold the power?
aren't those supposed to be rated much higher? did they warranty it or anything?
I have the 13.2 at 106 mph where my trap speed were closer to 110mph I was running the 2.5 liter built motor turbo charged at 10-12psi and bent my stock axle on the run due to the hard launch. I let off the gas when my wheel felt likr it was coming off but If i knew it was just a shaft I would have styed in it to get 13.0 more than likely. I never really had a chance to hot the track with 400whp yet but I imagine even granny launching I owuld eadily break 12 for sure. Joey
maybe but I was pretty sure on 13.2, either way, I was wondering why that's the fastest a contour has gone, there are a few contours with over 400whp, and there are other fwd cars with less hp running much better times. Is it just that nobody runs drag slicks or is there a weak link that nobody's found a way around yet when you reach a certain hp? I know traction is the ultimate enemy with these cars when you get to a certain level of power.
Only one person has run drag slicks and posted the time. Most people run street tires.
Axles snap occasionally but not necessarily everytime you get traction.
i think ryanblacksvts gonnna do it
put the big slicks and big axles and dump it at 8k
it will do something spectacular im sure of it
