kw8z3boi
What do you guy think of Coilover on Ebay? I just need to know if they're worth getting it. :laugh: I know is cheap and it might be bad springs or something else but just curious have anyone ever got it from ebay before?
and its a big advantage. with an adjustable ride height you can dial in the perfect drop. lowering a car gives you the obvious (but not a huge benefit) of lowering the center of gravity (CG). however if you also lower whats commonly refered to as the roll center (RC). the distance between the two is the roll couple. the greater the distance the more body roll the car will have. the problem is that the RC lowers more than the CG. so if you lower the car too far you can actually end up with more body roll even though you may not feel it due to the stiffer springs. if you "slam" the car, as many people do, the RC will end up at ground level or lower while the CG stays about where the crankshaft is at (not a perfect estimate but its a pretty good one). what needs to be done is to adjust the control arms so that they are pointed more upwards, the balljoint is lower than the mounting points on the subframe. this will bring the RC back up closer to the CG. the problem we, as contour owners, have is that nobody makes an adjustable lower control arm to do that. so what you get with the coilovers is a stiffer spring and the ability to lower the car without going to far or to little. you can go just enough that the roll couple is still managable with the spring rates and swaybars.Ride height adjustability is the only advantage.
False. not all stock and aftermarket replacement springs are progressive and not all coilovers are non-progressive.Stock springs, and most aftermarket replacement full size springs, are progressively wound, creating a stiffer spring the tighter it is compressed. Coil overs are not progressively wound.
i have seen single spring progressive coilovers. there arent many and the ones out there arent cheap.I have never seen progressive coil overs. I have seen attempts to make them so with two stage springs, one soft and one firm. I don't think it worked very well.
perhaps. i knew what you meant just didnt want people to think that ALL stock springs are progressive.As for stock springs being progressively wound, I guess you and I have not been looking under the same cars. Perhaps I should have said most or even many.
deffinatly. if you dont know anything about suspensions then just stick with the kits.Being able to adjust the ride height can be a big advantage, especially in competition. They have other limitations though. It is best to understand what you are getting into.
both are opinions since i dont imagine he put it on a skid pad before and after to measure the number of G's with each setup. ride quality is dependent on what you want/like. the ride of my car with the coilovers is not excessively harsh but it is deffinately harsher than stock or the BAT kit. however its what i wanted and now whenever i get into a car with a softer suspension i cant stand driving it no matter how well it handles. but thats just me.MattyK took the coil overs off his SVT and installed Bat Struts with aftermarket lowering springs. He is MUCH happier with the ride quality and overall handling.
