hotdimmes
why would anyone use nonconductive solder? Cmon dude, this isnt that hard. Test one LED with a battery or two (1.5V AA+ 1.5V AA) = 3V source. Figure out what's positive and negative on your LED's. On the switch, source with the resistor is positive(bottom of the switch assuming child lock is on left) and the other side where the series of LED's ends is the negative terminal. The child lock LED's are on their own current loop hence they get their own resistor. Remember that when you connect a series of LED's, connec the pos lead of the first LED to the pos terminal, then connect the negative lead of the LED to the positive of the next and so on until the neg lead of the last LED is connected to the neg source terminal. Also, I think the resistor is in between the first and second LED's, I thought that was kind of weird, but just go with it.
