hotdimmes
hotdimmes..any chance you have a pic of the "t" thing from when you were doing it. I'm working w/ a set that the slider does not seem to "snap" when it slides both ways. Instead it feels like when it's slide the one way the spring pushes it faster/harder....but when you slide it the other way its kind of like a mushy slide i.e. no "snap"....i think this is what is effecting my rear windows from working right.
Thanks
No pics but that is most likely your problem. I know exactly what you are talking about as I had a ton of problems with it. The best advice I can offer is to set the metal "t" piece down on the switch where it is supposed to go. Then, set the extension of the window lock switch from the cover in the notch in the "t" piece. Bot do so in a manner that it is almost exactly perpendicular to the "t" piece. Then, with both halves of the switch on their sides, push everything back together. This keeps the tab from the window lock switch from moving up or down due to gravity. Hope that helps.
