Ok, this may sound weird, but my engine is out of time. alot of symptoms point to it: lack power, hesitations, and little assistance from brakes due to low vacuum. No DTCs or check engine light
My problem: the marks on my crank damper do NOT correspond to TDC for some reason. (if i line up the 2nd mark with the oil pan, the #1 cylinder is NOT at TDC, its way off.)
Can i just pull another damper off any 95 contour or are each markings unique?
Thanks
Thanks
