99Mystique ATX
I would think it has to be done in series. considering in parallel the current would probably be near double, I at least wouldn't risk it in parallel
While this is true, you are also doubling the collapsing voltage by running it in series just due to how inductors work.
I've now got a full COP harness (Or maybe 2... ) off a bastard year taurus (2000) that I snagged at the junkyard yesterday. The harness is now cut apart and sitting on my work bench...
The difference between the Contour setup and the Taurus setup is that the Contour fires off one "pair" from one pin out of the PCM. The Taurus runs a common 12V and then 6 individual signal wires (one for each coil).
In a nutshell what we need is to find out is the inductance of the COP's as well as to figure out how the coil pack is wired internally. We can then figure out how things need to be wired in order to ensure reliable output without burning up PCM's or having poor spark output...
