qbcsvt
How do you adjust the shocks/coilovers with the KSports! I dont understand the top of the strut with the line measurements. Can you even do that while the strut is on ur car?
- amyn
- amyn
- amyn
Just get the Koni kit.
I know i'm jumping in late in this conversation, but it's driving me nuts. I read this forum a lot, but i hardly ever post. When i do post, I try to make a valid point that no one has made yet. In this case it's because there has been a lot of discussion on "adjustability". Yet no one has posted a single dyno graph on the two main dampers that seem to be discussed; the koni and the ksport. The only graph i could find directly comparing the two is on 240sx dampers, but it should show the true quality in manufacturing of the two different products.
Here is the comparison of of a pair the ksports. As you can see on the graph, to get these two dampers to a near even level, You would need to set one to full stiff, and the other to full soft. http://i11.photobucket.com/albums/a160/sleeper33/KsportRearFinal.jpg
Here's another pair of the ksports. As you can see again, It's nearly the same. So if you wanted an even level of adjustment, you would be left with no adjustment whatsoever.
http://i11.photobucket.com/albums/a...om/albums/a160/sleeper33/KsportFrontFinal.jpg
I'm only going to show one koni graph, because all the koni graphs i've seen have been very consistent. These are also a 240sx application. The konis are typically softer than the ksports in the applications that both companies make a set of dampers for. But koni uses a linear valve instead of a progressive valve, which reduces the need for more aggressive valving by offering more dampening earlier on in the bump and rebound.
http://i11.photobucket.com/albums/a160/sleeper33/konidynograph.jpg
So for quality, performance, and comfort i went with with koni. The only department ksport wins my favor is price. I compete in motorsports a lot and have seen many people go from ksports and teins to konis with ground controls. I have also seen very competitive drivers very satisfied with their ksports and teins.
HUH?
Is this english?
i was about to say the same thing. its english, you just have to understand it.C'mon now, the big kids are talking.
thats another good point. i plan on leaving it all the way up near stock ride height for now until i can get some roll center adjusters made to correct the geometery after i lower it.Another factor to consider here, as contourspd98 so nicely pointed out, is that the vast majority of contour owners (and all car owners for that matter) don't know JACK about suspension, and how different adjustments really affect how well the car handles. Most just like an aggressive feeling shock tune regardless of whether the car is actually faster around a track or not. And many like coilovers just so they can adjust the ride height for aesthetic purposes (not caring about what it does to the suspension geometry . . .)
