starjammir
Correct, I took my air hammer into it and that didnt help.I did some searching and people thought there were design issues with the Ksport. Hopefully Rara will chime in on that one.
Starjammer... so your saying the ends of the struts where to large to fit into the spindle assembly? Did you pry the opening up a little bit where the bolt goes through.
ya rara was complaining [for both ksport and d2] that there was no guide slot [or whatever his term was] where the strut attaches to the hub assembly... it would definitely be nice to have there.
starjammir, what your saying is a bit concerning. the strut should never slide in and out without a fair amount of effort... especially if there is no guide to lock it to the hub assembly. They seem to have very narrow tolerances on easy to assemble and near impossible to hammer on. I spray painted my rear hub assemblies and even a few coats of rustolium made it impossible to insert the [stock] strut... I had to take some sand paper and remove the paint from that area. If its too easy, you might want to add a bit of spray paint... better solution would to be to have that guide welded onto the strut [was thinking of doing that myself].
the other issue rara had with both the setups was the connector for the sway bar arms, in the fact that they way they lock down... or potential lack there of.
Ya it was a little bit wide on the strut side. Maybe just my car is weird or my ksports were just a little off. I dont know. I do know they have been on the car for 3k now with no issues
