fastcougar
He is nowhere near the limits of the crank ... the crank should be good for 900+ whp!
can you please prove that? yeah ok thanks try again soon.......
a duratec powered cougar around 900HP ???? lol riiight show me plz.
if you really think your oil was too thin, you need to step up to from an Xw30 to an Xw40 or higher. At 100+ degrees, a 5w30 and 10w30 are have the same viscosity, the difference in the two multi-weight oils is in the sub 100 degree temp. viscosity, where 5w would be thinner than 10w.
For sake of discussion, a 5w30 and 5w40 will both measure the same viscosity at say 50 degrees, but at say 115 degrees the 30 will be thinner than the 40.
