The car is a silver frost 2000 csvt with turbo. I'm the third owner ( original owner is cfcsvt )
Super fast and fun car. I use as a daily driver. Two issues could use a larger Maf and Shift cable .... which I will probably fix prior and does not have orig steering wheel.
Fully built 2.5l
Arias pistons
Pauter rods
New OEM crank
Fully built heads
Svt cams
Trans gears have been shot peened
Quife LSD
Driveshaft shop stage 5 kit: hubs and axels
Spec stage 5 clutch and flywheel
B & M short shifter
Bear 13" front brake kit
42ib injectors
Sct xcal3 with pro racer package. Complete access to ecu
Innovative lm-2 wideband monitor
Triple gauge pod w/ boost, oil psi and water temp
Koni shocks with intrax springs
Turbo kit: some of the kit was done by a shop in Tampa, I finished the rest.
Tial 38mm wastegate
Down pipe and turbo back housing are ceramic coated
The car has90300, everything but the brakes have 20,000 miles. The brakes only have about 3000 miles ( installed dec. 26 2013 )
This car is priced to sell at $5000.
Call or text to 772-353-1351 or pm here thanks
Fully built 2.5l
Arias pistons
Pauter rods
New OEM crank
Fully built heads
Svt cams
Quife LSD
B & M short shifter
42ib injectors
Tial 38mm wastegate
