About time for a real update, going all the way back to last May...
When I was still doing interior work and weight reduction, I found a really good example of why I was completely tearing the car down and rebuilding...you just never know with multiple-owner cars. One of the previous owners (or a shop) had bypassed the factory amp, but instead of using a few inches of wiring to do so, they had a 16 foot spool wound up and shoved behind the glove box. So addressing that was good for over a pound.
I rigged up a $10 axle tie-down strap for use as a cheap, simple, and lightweight front tow point:
I removed the power steering system, compression-fit the rack lines together, and plugged the valve body (I later completely removed the subframe and rack and cleaned everything):
I had the headers blasted to remove the remains of their old coating, re-coated them, and heat-wrapped them:
I test-fit the new lightweight Motegi wheels and installed the OE-style carbon fiber hood with black-anodized aluminum pins, and I hand-cut some vinyl livery for it:
Finally, I actually bought an engine! As I mentioned, it's from a 2005 Mazda Tribute with 39K miles. It looked kind of rough as purchased:
But throw a lot of money and time at something...
...and it cleans up ok!
The aluminum flywheel, new clutch, and transmission then went on, along with some ancillaries like starter, water pump and passages, etc. For the install, I decided to try a different approach and instead of dropping it in from the top as I'd taken the old engine out, I dropped the subframe, put the drivetrain on it and put the whole thing on a rolling platform:
This was definitely the way to go. All I had to do was lower the body down over it and roll the platform into alignment just as the engine and transmission mounting studs approached the brackets. It was much more safe and controlled than having it all hanging, and there were no tight clearances to worry about. Based on my experience both ways now, I'm an advocate of pulling the engine from below.
So that brings me to the present, where I am doing final rewiring, reconnection, and rerouting/fabrication of everything to make it actually work. I think I have a pretty good image for everything that's left to do, including how to use the reverse-pull Escape throttle body, but more on those issues after they're completed and working!
