realness1978
I am going to replace the valve cover gasket. I brought the valve cover gasket from autozone. The clerk suggested I put silicone on the valve cover along with the gasket for added protection. Do you think this is a good idea?
Did you also get the sprak plug well gaskets? Thats what you don't want to leak. You'll end up with oil in your plug wells, which will cause miss fires.
Did he mean high temp silicone RTV gasket sealer?
Yes he did. Here is a link to it. do you think it is necessary?
http://www.hardwarestore.com/pop-print/larger-image.aspx?prodNo=22513
should i replace the pcv also?
