95pgt-t
i dont understand why you'd put the plenum back on??? the opened tb i'm sure helps make the intake a little louder than you normal zetec:laugh:
matt,you can buy one of those 90* elbows for the breather port,that would help.
you need to put a ground wire on you IAT sensor
Questions:
- To what, and how, do you secure it to the car?
- What size is the plenum intake? 4"? 3" piping fit inside it... I need a coupler that will fit over this lip, and 3" doesn't cut it.
- It sounds like a ricer car over 2500 rpms!!! How can I stop this?!
No you don't. The PCM measures the resistance across the thermistor. The brass housing on the IAT sensor doesn't need to be connected to ground. Heck, the stock elbow has a brass intert in the plastic. Not grounded.
If it is really obnoxious then I'd be concerned that your static timing is off and there is too much valve overlap. Do you have any CELs right now?
our intake manifold does not have a plenum volume of its own large enought o keep a smooth idle. so we have a second plenum above out TB. with out without this added plenum you get an unstable idle.
You should secure the intake to the intake or motor. The intake needs to be able to move with the motor. If you anchor it to the body, you will be constantly flexing the couplers and they will crack/break over time.
I have the old CTA intake, so there is no plenum on my car yet my idle is pretty smooth :shrug:
The CTA intake has a metal piece that connects to the MAF and bolts onto the tranny mount bolt... If you want I can get a picture of it Matt...
i thought the sensor, like others, had a 2 wire plug going to it. Which then he would need a ground for the sensor. I have the 6wire MAF so i wouldnt know for sure. it just seemed logical. good call on the correction though.
thats what ive said a few times, but it seems to have been ignored.
