Savior
Is it difficult? I'm sure I can do this myself with a little instruction. Shotwell informed me that I should use Royal Purple SyncroMax manual transmission fluid, and I'll need about three quarts.
But as to the actual procedure, could someone post some pics of the underside of the tranny, indicating where the drain and fill bolts are, and maybe tell me what things I need to buy from my local AutoZone/wherever, like a transmission funnel and stuff like that?
Also, I somehow got the impression that you have to drain the fluid out, and then actually pump the new fluid up into the transmission using some sort of small pump and tubing assembly...? Is this right?
