bullion
I am selling my SVT exhaust in the classifieds section and someone asked me if the exhaust will bolt up to a 98 SE. Will any modification be needed for the buyer to do this?
Unless the SE exhaust and SVT exhausts are different lengths, it sounds as though you would have to cut off the 2.25" flange of the SVT exhaust and weld on a new 2" flange adapter pipe to make this work.....
Am I missing something?
I've helped with a few of these. It's a plug and play except for adding a right side exhaust hanger.
You need an extension when adding it to a Zetec.
There are two SVT exhaust systems. Early and late. It may break down along E0 and E1 lines. The difference is in routing around the gas tank. You can use a late set on anything, but the early one must go on an early car or you will have a conflict at the gas tank.
For future reference and to help someone later down the road...I ran into this problem. I traded some car parts for an SVT exhaust for my daughter, she has a 98 1/2 SE. After reading all the "it's plug and play, just add a hanger" threads I figured there was going be no problems. Wrong! I found out later that this exhaust was from an early 98 and that is why it wasn't "plug and play". After having to get the exhaust cut, pieced and re-welded to fit, it was finally on.
So, for those of you with later 98's and up, make sure to ask if you are getting an exhaust from an early 98. It's better to know up front so you can make accommodations when having it installed.
