so I was looking at my power steering lines because they are leaking and we noticed this...
This is a picture taken from under the car behind the engine. Basically looking straight up from the rear header. It looks to me like an oil leak, possibly from the head gasket. As you can see, it's leaking down the block and it's also on the header flange. It's not leaking bad as it's only half way down the block, not dripping to the ground yet. Also, to the right of the oil, under the header flange it looks like black soot or something, maybe an exhaust leak?
I purchased this car a couple months ago and haven't driven it yet and I want to take care of this before I start driving it. So if that means doing a head gasket and all gaskets with it then thats what I'll do.
So does this look like a head gasket to you guys/girls?
If so, what gaskets should I be doing so when I go to order/purchase these I make sure I get everything. Also, should I go OEM or should I just go to AutoZone and buy Fel-Pro or Rol?
Your help would be greatly appreciated, TIA
