I just picked up the Dixis Titanium Exhaust and H pipe, used (1500 miles old).
The Dixis is 26.4 lbs. The band clamps (not included) are 1.1 lbs. The stock rubber hangers (reused) are 1.3 lbs. That's a total of 28.8 lbs. The stock exhaust is 79.8 lbs. That's a 51.0 lb difference between the Dixis and the stock system.
Here are some pictures.
Stock exhaust:
Stock neck-down:
Here's a look at the stock main cats attached to the headers, sometimes called the precats. They're metal matrix, but high cell-count:
Here are the secondary cats, sometimes mistakenly called the main cats:
The first thing that had to be done is cutting the stock pipe. The pipe was cut, then the cut was smoothed, so that it doesn't impede exhaust flow.
Stock exhaust:
Stock neck-down:
