the purpose of oil is to keep your engine well lubricated. if you want to believe motor oils will last for 5k, 10k, 15k, or 25k, then go ahead and service your engine at these intervals. because they actually will. the oils are proven to not break down until a certain milage point. but the oil still is home to many particles of crap that filters cannot pick up, especially after 3k which is the reccommendation from your owners manual for severe driving. no one on this forum falls under the catagory of "normal driving conditions," no matter how much you pamper your engine. with all this crap that's just floating around in your engine, what's lubricating it? :shrug:
so yeah, your oil might not break down for a while but every time your engine is running it shaves off the tinniest metal fileings that get caught inbetween your moving parts, which i personally don't want floating through my engine.
the next time you change your oil, cut open your oil filter and look at how many shavings are sitting in between the paper fins. the oil filter does it's best to pick these up, but can't get them all. imagine those all at one time traveling through your internals before it gets to your filter. IF the filter even picks it up. then imagine running the same oil for 3000 miles. if your rpms average 3000 on the freeway and drive at a mile a minute, your engine goes around 9,000,000 times before you change your oil. that's a lot of wear on your parts.
the best thing to do if you really want to run the oil for that long is to still change the oil filter every 3k. but doing that, you still have to get another quart of oil to top off what was lost from the filter.
but seriouisly what's the point. if your going to go through the hassle to change the filter, you might as well take out the plug and drain the oil too.
i can't stop you from going long intervals on your engine oil, but if you're a real entusiast who actually cares about their cars, you might want to keep them running clean.
i run mobil one extended performance and a wix filter and change the oil every 2500 miles. i have 170,000 miles on the engine and had never had problems.
