I managed a 13 second pass with my Hybrid. Only once though. I am consistently @ 14.1xx.
The car went 13.98 @ 100.73 MPH (IIRC)
Mods are as follows:
BuckShot Prepped 3L
SVT Heads W/ST220 Valve Springs (Freshened up)
SVT Cams
GreenCountry Transmissions Rebuilt Tranny
Quaife LSD
Spec Stage III Pucked Clutch
Lightenned SVT Flywheel
B&G 1.6" Springs
KYB Replacement Shocks (Yuck...I Know)
St200 17" Wheels
Michelin Pilot Sport Tires 215 Width
B&M Short Throw
No Resonator
No Cats W/MILs
Taylor Spiro-Pro Wires W/ NGK Iridiums (Added this in editing)
Open Element Air Filter
The Most important thing to note about my setup is that LITERALLY EVERY moving part in the motor was replaced with new parts out of the box. I didn't reuse anything but the cams and Valves.
I also removed ALL A/C Components, Added Carbon Fiber Hood, AAS Fiberglass Front Bumper, removed Spare and jack/accessories, and ran with less than a quarter tank of 91 Octane Fuel. This all helped in the weight savings dept.
I believe with proper tuning and a decent exhaust and header upgrade that I can be a consistent 13.9-13.6 SVT.
Track Conditions:
64 Degrees Fahrenhite(SP?)
Fresh VHT (Which I think hindered the process more than helping on street tires)
No Humidity outside
No breeze
In Short, it was a perfect night to be at the track.
I Have noticed that when barometric pressures change, the times will change with the pressure increase.
