Ok, so let me get started. The center of my build is an 04' Sable engine with 6,100 miles on it. I've been accumulating parts for the last 8 months, and the engine will be going in during the second week of May with BAD SVT's help, and whoever wants to come down from PHX for free beer and food :crazy:
1998 E0 LX w/MTX
The basic build will be:
-engine-
04' block/lower
SVT UIM
NPG lower intake manifold adapter - delete IMRC and no porting for me to do
02-04 Escape fuel rail - for NPG adpater/SVT UIM clearance
NPG fuel rail mod
65mm optimized TB w/SVT throttle cable
Escape oil pan
Bracket-less oil pickup
DMD
EGR delete
Ford racing plug wires
Autolite double platinum plugs
NPG tune w/Xcal3
Pole RR's in 94a
-exhaust-
Coated MSDS headers
Sho-Shop y-pipe/cat
True Borla SS exhaust
-tranny-
Upgraded 1998.5 E1 MTX-75 w/Torsen & shift forks
OEM SVT clutch
Short shifter generic knock off of B&M - already installed
Stuff I know:
1. Flip key position on pulse wheel
2. Cut off tabs from block for alternator
3. Use 2.5L timing cover
4. Xcal tune needed for 24lb injectors, EGR delete, IMRC removal
Random questions:
1. I know I can't use the 3L dipstick and tube with the escape pan, but can I use my stock 2.5L ones?
-Use 2.5L w/ Escape pan
2. Does anyone have pics of their pilot bearing/transmission input bushing removal?
-We'll just cut it off
3. Are there any oil/water passages I need to block of with this setup?
-No
4. What 24lb fuel injectors should I use for correct spray pattern - wiring harness is a E0 and I'm ok with using adapter plugs, unless that option is unreliable/won't fit?
-NPG will be supplying 24lb oval-port spray pattern injectors w/ E0 connectors
5. Educate me on which knock sensor to use (2.5l or 3.0l) and how to modify/include it?
-I'll use the 3L and splice it in if my harness has the option
6. Where is the hole/port I should use on the block for the supply line of my Autometer oil pressure gauge?
-Above AC compressor (thanks Blu & BAD)
7. Advantages of SVT vs 3L cams with this setup? (If there isn't much gain I'm inclined to keep 3L cams)
-keeping 3L
8. Options and costs of shift tower improvements - keyed...etc?
-keeping stock E0 setup
9. Advantages and costs of using 01/02 Cougar alternator?
-Keeping stock Contour one
10. Diagram/pics of modified E1 passenger side motor mount - stock E0 too large?
-Purchasing E1 or 01 cougar mount - which ever one is cheaper
11. Any issues with 1998.5 E1 speedo sending unit on new tranny with my E0 speedo cluster?
-Should work for any 98-00
12. My shifter has front to rear slop (approx 1" of play when in neutral), and sometimes pops out of second gear when shifting - what are the right shifter bushing ends I need to restore this? (I found F7RZ-7412-AA for the white end, and[FONT=Times New Roman, serif] XS8Z-7412-GA [/FONT]for the black end)
13. Can I use my 2.5L valve covers on the 3L heads & 3L cams - any clearance issues? (I want to keep stock PCV and not have to buy the spacer for the UIM)
-2.5L valve covers clear stock 3L heads
14. I want to use an upgraded hose for my oil pressure gauge, either the solid copper tube or new SS braided hose. How long is your tube/hose - 6ft?
-I'll use the 10ft nylon hose that comes with the gauge to measure the length, then probably go with copper, as SS will be over $75
I'll post up pics as soon as I can, and advance thank you's for everyone's help with this project!
1998 E0 LX w/MTX
-engine-
04' block/lower
SVT UIM
NPG fuel rail mod
Escape oil pan
DMD
EGR delete
NPG tune w/Xcal3
Pole RR's in 94a
-exhaust-
Coated MSDS headers
Sho-Shop y-pipe/cat
-tranny-
OEM SVT clutch
Stuff I know:
Random questions:
-No
-keeping 3L
