ok I checked all the fuse's (10 amp under hood) all are good besides if one was bad then they wouldn't work with DRL's or not .When I started this project everything was working proper. I also allready have a working fog light mod. So when I put in the relay (autozone special) and turned on the car I had working DRL's but when I turned on the highbeams only the passanger side high beam worked. Fog lights work ok lowbeams ok just no driver side high beam with DRL mod:shrug:
