hetfield
or hetfeild
When I got #1900 I was told the interior lights don't work. The fuse was blown, and putting another one in blew within 10 seconds, but not immediately. My fear is that there is some bad wiring somewhere. I want to make sure I understand the routing and accessories that are fed from that circuit. From what I've read it runs up the driver's footwell and feeds across to the footwell lights and the radio. It also runs up the A-pillar and feeds the power mirrors, dome lights, and the passenger visor lights. Being a 2000 it doesn't have a clock, but is there wiring on that circuit that still runs to the panel with the PATS light on it?
I've removed the dome lights and that didn't help. I'm going to disconnect everything on that circuit and try another fuse. If that doesn't work I'll need to check the wiring. To try and make things simple and not have to tear out the entire dash I'm thinking I could use a multimeter to test continuity from each plug back to the fuse panel. Does that make sense? I'm not the best when it comes to wiring...
