Ú--------------------------------------------------------------------------------------------------¿
| Pin | Circuit | Wire Color | Application | Abbreviation |
| 1 | 91S | BK/BL | Shift Solenoid 2 | SS2 |
| 2 | 91S | BK/O | Malfunction Indicator Lamp | MIL |
| 8 | 91S | BK/BL | Intake Manifold Runner Control | IMRCM |
| | | | Monitor | |
| 13 | 8 | W/BL | Flash EPROM Power Supply | FEPS |
| 15 | 9 | BR/BL | BUS (-) | BUS - |
| 16 | 8 | W/BL | BUS (+) | BUS + |
| 21 | 8 | W/R | Crankshaft Position Sensor (+) | CKP + |
| 22 | 9 | BR/R | Crankshaft Position Sensor (-) | CKP - |
| 24 | 91 | BK/Y | Power Ground | PWR GND |
| 25 | 91 | BK/R | Case Ground | CASE GND |
| 26 | 9 | BR/BL | Ignition Coil 1 | COIL-1 |
| 27 | 91S | BK/Y | Shift Solenoid 1 (CD4E) | SS1 |
| 29 | 14S | P/BK | Transmission Control Switch (CD4E) | TCS |
| 30 | 8 | W/BK | Octane Adjust | OCT ADJ |
| 31 | 8 | W | Power Steering Pressure Switch | PSP |
| 35 | 8 | W/BL | Heated Oxygen Sensor - 12 | HO2S-12 |
| 36 | 9 | BR/BL | Mass Air Flow Sensor Return | MAF RTN |
| 37 | 8 | W/R | Transmission Fluid Temperature | TFT |
| | | | Sensor | |
| 38 | 8 | W/GR | Engine Coolant Temperature Sensor | ECT |
| 39 | 8 | W/P | Intake Air Temperature Sensor | IAT |
| 40 | 14S | P/BK | Fuel Pump Monitor | FPM |
| 41 | 14S | P/BL | A/C Cycling Switch | ACCS |
| 42 | 91S | BK/R | Intake Manifold Runner Control | IMRC |
| 45 | 91S | BK/BL | Low Fan Control | LFC |
| 46 | 91S | BK/W | High Fan Control | HFC |
| 47 | 91S | BK/GR | EGR Electronic Vacuum Regulator | EVR |
| 48 | 8 | W/BK | Clean Tach Output | CTO |
| 51 | 91 | BK/Y | Power Ground | PWR GND |
| 52 | 9 | BR/GR | Ignition Coil 2 | COIL-2 |
| 54 | 91S | BK/W | Torque Converter Clutch Solenoid | TCC |
| 55 | 89 | O/Y | Keep Alive Power | KAPWR |
| 56 | 91S | BK/O | Vapor Management Valve | VMV |
| 57 | 8 | W/BK | Knock Sensor | KS |
| 58 | 8 | W/P | Vehicle Speed Sensor | VSS |
| 60 | 8 | W | Heated Oxygen Sensor - 11 | HO2S-11 |
| 61 | 8 | W/GR | Heated Oxygen Sensor - 22 | HO2S-22 |
| 64 | 8 | W/GR | Transmission Range Sensor (CD4E) | TR |
| 64 | 8 | W | Neutral Gear Switch/Clutch Pedal | NGS/CPP |
| | | | Position Switch (Manual | |
| | | | Transmission) | |
| 65 | 8 | W/BL | Differential Pressure Feedback EGR | DPFE |
| | | | Sensor | |
| 69 | 91S | BK/Y | Wide Open Throttle A/C Cutoff | WAC |
| 71 | 95 | GR/Y | Vehicle Power | VPWR |
| 73 | 91S | BK/GR | Injector 5 | INJ-5 |
| 74 | 91S | BK/BL | Injector 3 | INJ-3 |
| 75 | 91S | BK/W | Injector 1 | INJ-1 |
| 76 | 91 | BR/W | CMP/TSS Ground | CMP/TSS GND |
| 77 | 91 | BK/Y | Power Ground | PWR GND |
| 78 | 9 | BR/Y | Ignition Coil 3 | COIL-3 |
| 79 | 8 | W/BL | Transmission Control Indicator Lamp | TCIL |
| | | | (CD4E) | |
| 80 | 91S | BK/BL | Fuel Pump | FP |
| 81 | 91S | BK/R | Electronic Pressure Control (CD4E) | EPC |
| 83 | 91S | BK/Y | Idle Air Control Solenoid | IAC |
| 84 | 8 | W/P | Turbine Shaft Speed Sensor (CD4E) | TSS |
| 85 | 8 | W/P | Cylinder Identification | CID |
| 86 | 91S | BK/W | A/C Pressure Switch | ACPSW |
| 87 | 8 | W/R | Heated Oxygen Sensor - 21 | HO2S-21 |
| 88 | 8 | W/BL | Mass Air Flow Sensor | MAF |
| 89 | 8 | W | Throttle Position Sensor | TP |
| 90 | 7 | Y | Vehicle Reference Voltage | VREF |
| 91 | 9 | BR | Signal Return | SIG RTN |
| 92 | 29S | O | Brake On/Off Switch | BOO |
| 93 | 91S | BK/Y | HO2S Heater - 11 | HTR-11 |
| 94 | 91S | BK/BL | HO2S Heater - 21 | HTR-21 |
| 95 | 91S | BK/O | HO2S Heater - 12 | HTR-12 |
| 96 | 91S | BK/GR | HO2S Heater - 22 | HTR-22 |
| 97 | 95 | GR/Y | Vehicle Power | VPWR |
| 99 | 91S | BK/R | Injector 6 | INJ-6 |
| 100 | 91S | BK/O | Injector 4 | INJ-4 |
| 101 | 91S | BK/Y | Injector 2 | INJ-2 |
| 102 | 91S | BK/O | Shift Solenoid 3 | SS3 |
| 103 | 91 | BK/Y | Power Ground | PWR GND |
À--------------------------------------------------------------------------------------------------Ù
