Ra\/en
Hi everyone,
My air and everything was working great, then yesterday it started to cut out a little when I would start the car, then it would come right back on. But, in the evening, I reset the Car's ECU by pulling the fuses to do so, so that I could get rid of a CEL that I had on for a transmission related issue. I start the car and nothing blows out of the any of the vents. Not even on High. I have replaced the resistor pack thing years ago and it still looks good, that is not the problem. I also can hear the AC kick in so I know the AC itself is working.
But I also check the blower motor itself by hot wiring it to the battery. It works. The connector and wires that plugs into the blower motor look good. The fuses #23 and #37 are good. The connector that goes into that fuse box inside the car all look good and the panel itself looks good. Wires too.
I also replaced the blower Motor Switch that the knob connects to. That didn't work. The connector and wires that plug into that also look good.
What else can I check? It is getting hot here in Indiana and it is only going to get hotter this week, into the 90s.
Please chime in with any suggestions on what I can check.
Thank you.
Thank you.
