Posts: 81 |
Originally posted by todras: Their is no IMRC bracket. Just bolts to 3 points on the front valve cover. No, you can't fix an IMRC. Can't buy the parts seperately. Have to buy and entire new IMRC.
...the bracket the cable for the IMRC goes to....since mine is a 95/96 that was in question, but there is that little bracket to hold the cable. On the front valve cover there are no standoffs to hold the IMRC controller box though so I will need to fab something up.
Posts: 3,037 |
It sounds to me like you need a '96 or later LIM and an IMRC controller, and you *should* be set. I don't know if there's any difference in the intake ports from the '95 heads to the '96 heads; probably not but with the OBD changes, you never know.
The '95 LIM/vac secondaries were open when the engine was off but closed as soon as sufficient vacuum pressure was achieved at startup. I always liked that gutteral growl that my '95 made, like a big critter pissed off at being woken.
Posts: 81 |
also whats a good source for a cheap IMRC? anyone parting anything out? In classifieds it didn;t look like anyone had an extra
Posts: 81 |
Originally posted by Jeb Hoge: It sounds to me like you need a '96 or later LIM and an IMRC controller, and you *should* be set. I don't know if there's any difference in the intake ports from the '95 heads to the '96 heads; probably not but with the OBD changes, you never know.
mine has that growel, but it is covered by a clattering sound on startup.....maybe chains? who knows but after a few seconds it is gone and the engine runs happy
Posts: 21,197 |
Yes, it's worn chain tensioners. More prominent on 95 cars. They were revised for '96. Can still happen to later cars though as witnessed on Snakous' car.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 21,197 |
I might have access to a 96+ front valve cover for you.
-'96 SE MTX 3L
Posts: 5,345 |
Originally posted by TravisN1: ...a clattering sound on startup.....maybe chains? who knows but after a few seconds it is gone and the engine runs happy
Could be chains, there is a TSB (it is aesthetic), or it could be a loose heatshield for the main cat (I used a $5 exhaust repair strap from Advance).
1996 V6 ATX 96K miles
Posts: 81 |
is the chain clattering anything to worry about? I know in the 97 explorers the SOHC engine had faulty chain tensioners and several people lost their engines because the tensioner broke off.
Posts: 81 |
Originally posted by todras: I might have access to a 96+ front valve cover for you.
that would be cool if i got a IMRC, conformed it worked, then threw on a 96+ valve cover maybe it would work out well thatway.
Posts: 5,345 |
Originally posted by TravisN1: is the chain clattering anything to worry about? I know in the 97 explorers the SOHC engine had faulty chain tensioners and several people lost their engines because the tensioner broke off.
You decide.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=18
If you want to fix it, here is a TSB for the chattering sound.
http://www.contour.org/FAQ/tsb/content/97-2-8.html
