Posts: 725 |
what if you change the starter, inspect the flywheel and it looks fine but it still grinds the odd time (once a week on average). i had this problem for 2 years now but it comes and goes, it has gone as long as 3 to 4 weeks without grinding and as bad as 2 or 3 times a day. BTW i have the Fidanza Flywheel and i have about 30k on it.
95 SE MTX
DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
Posts: 5,345 |
Originally posted by abwamo: what if you change the starter, inspect the flywheel and it looks fine but it still grinds the odd time (once a week on average).
You sure it isn't the weird "clattering/rapping" start up sound that some of us have every now and then.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=18
http://www.contour.org/FAQ/tsb/content/97-2-8.html
1996 V6 ATX 96K miles
Posts: 725 |
no this the sound you get when you try to start the car while its running " a grinding sound". i'm familiar with clattering on my 95, it doesn't bother me.
95 SE MTX
Posts: 6,700 |
Originally posted by Tony2005: Originally posted by abwamo: what if you change the starter, inspect the flywheel and it looks fine but it still grinds the odd time (once a week on average). i had this problem for 2 years now but it comes and goes, it has gone as long as 3 to 4 weeks without grinding and as bad as 2 or 3 times a day. BTW i have the Fidanza Flywheel and i have about 30k on it.
I have this issue on my 00 CSVT. Push the clutch in, turn the key, GRIND, do it again, starts fine. My CSVT has had the starter replaced before.
I ALSO get the chattering noise described to only happen on early V6 motors on any cold start up. After reading that second link you posted Tony, I think I might make an apointment to have both that AND my flywheel looked at, as I have a feeling it's got some chew marks on it.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
