Hello, I'm new here and in the process of installing the new timing belt(after a breakage)
I hope for some clarification on my current problem.
I have a 1999 Mercury Mystique with the 2.0 Zetec 4cl and a broken timing belt. I have the crank aligned at TDC as well as the twin cams with the special cam tool, belt ready to slip on. Question is, the front(exhaust cam) has some sort of hydraulic mechanism on the sprocket and the sprocket turns about an inch and a half before the cam starts to turn. I can turn the sprocket enough to get the cam tool to slide into the cam slots, but when I release the sprocket with my hand, it puts stress on the cam against the cam tool. Is this normal?.
I would appreciate any help and I will try my best to explain better if you want me too.
Nice website and thank you
(Eric)
(Eric)
