Teal4Banger
The P0420 is because you don't have a MIL on your lower O2.
The P0171 is interesting. How old was your upper O2 before doing all of this. All of the wrenching/movement may have killed it.
Did you reset your PCM after doing everything? Pull the little 3 amp fuse in your fusebox and let it set for 5 minutes (with the car off).
BTW, I've always wanted to try this...
Do you notice surging at part throttle? I've always wondered if you could just cut the EGR pipe after the cat and just put a small air filter on it. To bypass the EGR system, not have it throw a CEL, and have a nice clean intake manifold all at the same time.
HTH,
BP
The first o2 sensor is almost new (about 2-3 months old).
I had the battery disconnected while doing the header so the ECM should have been reset. I cleared the codes today, if they come back I'll reset it again.
I haven't noticed any surging, in fact, I havn't noticed any problems other than what's mentioned. After cutting the EGR tube, I noticed minimal air flow from it. Mainly I just want to hook it up to the cat so everything is as it should be and proper. I can be anal about things like that.
