Redlineracer12
Good deal, what do we get for options then? I know it was discussed that there will be different upgrades... Does this include an xcal2 or no?
Since the xcal / chip wont be included in the kit (from what I see). What do you suggest for tuning methods.
When will you start accepting deposits, and how much.
would it be possible for those of us that do not have SVTs to get two springs, one for a lower psi to start with if we are not comfortable going to 7 psi off the bat or don't yet have the trans upgrades to handle that power?
The kit will sell for $2825.00
This includes :
so might it just be better to stick with the 7 psi spring and get a manual boost controller to turn it down? or is it better to get a lower spring then use a manual boost controller to turn the boost up?
Unless you have a nice electronic boost controller like an Apexi AVC-R you won't be able to lower the boost from what the wastegate is set at. You will go by the spring or higher.
