Thanks for the info. I'll try the MAF cleaner and then replace. Also that is a good idea for the fan. I suppose I could check this. I could probably measure the fan sensor. I imagine it shorts to ground when the temp is reached so if I check it now it will probably be shorted.
I could order a MAF from Ford but it would be nice to pick one up at the local autozone and be fixed today. they do have a one year warranty. Are the MAFs from the non-Ford part houses known to have premature failure or do they operate differently than the Ford part?
When it comes to sophisticated electronic equipement and sensors, I go Ford only. An example that comes to mind is the idle air control (IAC). Folks on here have tried aftermarket examples with less than satisfactory results. I'm a big fan of saving labor, as well as the "once and done" approach.
I'm not saying you couldn't get away with an aftermarket application, but you best be damn sure the metering is identical, or you could run into problems bigger than just hesitation. To wit, some SHO folks at one point were wondering if they could swap the larger MAF from a 3.8L Thunderbird SuperCoupe and use it on a Taurus SHO. The answer, of course, was a big, fat, no. The SC's air/fuel needs are decidedly different, and are not compatible with the SHO. The swap goes a long way toward screwing up the drivability that Ford worked so hard to optimize. I'd use this example as a guide in choosing your part.
FoMoCo -- the way to go.
