What kind of bulb?
pipedsvt
Ohio
I am tearing out my oem green lighting in my car and replacing it all with blue LED's. Can someone tell me or show me a picture of what the bulbs look like in the HVAC unit?
Thanks
im assuming since you only asked about the HVAC you found all the posts about the gauge LEDs. The problem with the HVAC is that there is only 2 bulbs lighting up the whole thing. If you just replace them with LEDs you will not get everything lit up. also, removing the green from the HVAC is damn near impossible as its very thin and you can easily remove some of the black and screw up the HVAC.
this is what i did
however it requred 6 LED bulbs, 4 blue and 2 red. They are 194 matrix LED bulbs from autoumination.com
it also requires that you use the originall overlay from a pre98 as they had a more bluish tint to the green film. you can see the difference here.
