tvissoc
I've just finished dropping in a replacement stock motor in a '98 v6 automatic. Having issues with injectors firing (I think). I don't think this connector will cause the injectors not to fire, but it definitely should be hooked up. What does it connect to? Everything that I can see is hooked up, but obviously I've missed something.
Also, any tips to help troubleshoot non-firing injectors. I sprayed some starting fluid in the side of the air intake where the breather tube hooks up. It fired when cranking, so I assume the injectors are not firing. I get spark, I've got fuel at the rail, etc.
Note: The harness was a mess. I repaired many sections of both the main and injector harness. It could be a bad repair or something I missed. I could be looking at replacing the harnesses.
Thanks,
Tony
Thanks,
Tony
