Interesting on the rocker ratio.
So, if you use SVT cams in an '03+ 3L can you use the higher lift rockers?
Seems like the way to get the highest duration/ additional lift.
I've been following the thread, but if I build a 3L it will have the SVT cams. From what I've read, the SVTs have the same lift as later 3L cams but have more duration/overlap. This will give more top end and can soften the low/mid-range slightly, which is probably what people are describing here. If the car is tuned properly, the SVT cams will make more power from say 5000-7000 (arbitrary range I made up that would need to be dyno verified, but they will show gains from a certain rpm to redline).
SVT chose the cams for these cars and I would stick with them if possible.
-J
