I dunno about a breaing puller ... these bearing have to be removed and installed with a hydraulic press ....
how will u know when the bearing has seated? with hub installer i ordered, it screws onto the axle threading and pulls the hub into the bearing so it seems it wont be stressing the ball bearings. the axle will be back in thru the bearing and then the hub goes on with the installer then attached on the outside of the hub thru the center to the axle threading, sorta like pressing a new wheel stud in, well sorta.
i'll give the inner tie rod test a shot and the wheel spin test. i mentioned i though it was bad cuz i saw in and out movement of the joint on the inner side at the steering gear when doing the 9-3 oclock test. i would think that joint shouldnt move
You can do it with a fair sized hammer, vise, and a punch.
When installing a new bearing, the bearing is first pressed into the hole in the knuckle until it is seated, with force applied to the OUTER RACE. The two snap rings are then installed, and then, WHILE SUPPORTING THE INNER BEARING RACE, the hub is pressed into the bearing. If you fail to support the INNER RACE, the bearing becomes brinnelled and will fail in a short time. Simply put, you never want to transfer the pressing force through the balls of the bearing.
absolutely do not install a wheel bearing in this manor :nonono:
I read that as there is no other way to get them out, and I disagree. I always used a hub-shark when I was working with bearings... best tool imo.I dunno about a breaing puller ... these bearing have to be removed and installed with a hydraulic press ....
You just said I read that as there is no other way to get them out, and I disagree. I always used a hub-shark when I was working with bearings... best tool imo.
you will be able to reinstall the snap ring. if the bearing isn't in far enough your not getting the snap ring in.
