S2Knott
just wondering how much lighter the fidanza 9 lb flywheel is than the SVT flywheel (dunno how much that weighs) and if its worth it to get a Fidanza flywheel.
I would expect your idle to be lumpier than canned gravy. Certainly, the throttle response will be quick. For what its worth, I've driven a SHO with an 8 pound flywheel and a Spec 3 clutch, and the combination is often a pain in the as* to drive. Once you're up and running, the car is fun (SHOs are a blast even bone stock, anyway), but when you're nursing the car through traffic, trying to make a quick left from a stop into the AutoZone parking lot, its a bit of a bear. Its doable, understand, its just not very user friendly.
Unless you are dead set on spending too much money and possibly introducing new problems, you made the best choice with the SVT setup. There's nothing to regret.ended up getting stock svt clutch/flywheel from teamford... didnt have the money for the better stuff.
Karl
stage 3 is a light switch anyways, stage 3+ is better for streetability
