warmonger
Looks more like tuning to me. Torque rises smoothly to about 320ft-lbs, then falls off jaggedly, then towards the end of the rpm range it jumps back up to where it "should" be. It looks like a spark issue, perhaps indicating too much timing being pulled while in the midrange rpm.
If you aren't getting any misfires I mean. If the power still feels smooth and no surging in the midrange, then I'd surely look to adjust my timing.
This also makes the assumption that you don't have too much timing because that would probably break a piston or rod. Therefore it looks like the timing is being pulled too drastically for some reason.
Perhaps by the tune due to a knock sensor, intake temps, or another reason. It doesn't make sense that it can just bump back up by 50ft-lbs of torque at precisely 6500rpm. It seems the PCM is getting a false indication or the tuner pulled too much automatically.
If the timing was being pulled for one of these reasons, since intake temps will still be rising then it wouldn't suddenly be able to safely jump up by that 50 ft-lbs. Now possibly it could with the knock sensor but that raises doubts in my mind.
If I recall, the knock sensor pulls timing in the low range from maybe 1500-5000 or so where sometime above there it is disabled automatically by the PCM. This is because there are too many false 'noises' in the engine that would falsely trigger it at higher rpms. It is really only useful and only used in the low rpm ranges. Might be you have a sensitive one, or the wrong one and when the RPMs climb the PCM is turning it off, which stops timing being pulled and the engine goes back up towards smoother performance. That would also explain the jagged nature of the curve. If it is giving you grief you can shut it off in the tune and go with experience on how much timing to run at those RPMs.
Anyway, that last little bump in the power tells me that it isn't a boost leak or a wastegate issue becuase that suddenly doesn't get better as the turbo is blowing max air at max rpm.
Oh, and I ate, breathed, and slept car stuff growing up so it just sort of stuck in there and I built upon it. lol
Thank you Tom, I meen damn dude where do you keep all that knowledge, do you have a storage shed in your mind:laugh:
But I think I may have the same problem that Brapple has as well. You tell me by my dyno chart Tom. This was with the old rfl that was leaking. I dont know what spring is in the wastegate.
