rexxdoggy
I had replaced mine with, from what svttour said, was an older style VSS, which needed to be capped off. I didn't want to close it off with some kind of, whatever, don't even know how to describe it. So what I did was, I took my old one, snipped off the wires, which was bad anyways, and used it to screw onto the new one. I did have to chop off the little thingy in the middle for it to screw on. ANYWAYS, I think that may what have done it.
ONTO THE PROBLEM. Speedo isn't smooth as it should be. Anywhere from 0-60 or 65, it smooth-ISH. Then after that and above that speed, the speedo bounces all over the place. It doesn't want to read completely accurate. It bounces around from like 5-8 MPH of what the actual speed is. Is this due to the fact that I have it capped off with the older one and didn't snip off that prong thingy enough?
