qbcsvt
I never seen the vortech setup. I wanna see it in your Contour
Meet at your house?
- amyn
Meet at your house?
- amyn
I'm pretty sure Vortech never outsourced anything. Thomas Knight built his own kit which had major bearing issues.
i brought the supercharger to a local machinist a while back and we pressed off the bearings. there are only two bearings in the setup, and they are very close together. so in theory, the side pressure is way more than it needs to be. the machinist suggested i buy 100,000 rpm ceramic sealed bearings and press as many as i can fit in there (approx 6) which will reduce the side pressure, through more surface area for the shaft to ride across. however the bearings were 47 bucks apiece and i just can't justify putting a couple hundred bucks into another failed attempt with the t-knight supercharger. i had it working for a week the second time i had new bearings installed. it was boosting 5 lbs through the supercharger (hardly noticible power gain). so i put the supplied 2 1/4" piping in without the intercooler and it boosted 8lbs and was much more noticible. all of this was done without a tune and used a SAFC for fuel advances which is unacceptable. i can see this kit working but i don't have the patience for it anymore. i basically tried to give it away for a couple hundred bucks for someone that wants to make it work but nobody would grab on it. so its a paper weight
:help:The spline design works, too. It just doesn't work correctly "out of the box." Take a good look at a completely original spline Vortech setup and you'll see why the splines fail.
:help:
The spline design works great out the box. It's long term use that wears out the splins and they strip.:blackeye:
That's my point. It does not work correctly. The splines strip out. However, it can be fixed so they don't.
Meet at your house?
- amyn
Do you use an S-trim head unit?For pictures of my Vortech kit click on my sig and look at our site. We have pictures of it on my Cougar and on my old Contour.
self contained? nice. didnt know they did cintrifucal units that were self contained
Procharger has done this for a while and now Vortech too, maybe Paxton.self contained? nice. didnt know they did cintrifucal units that were self contained
They will be phased out for the updated Si units and you can also get them self-contained to prevent having to tap the pan.
You may already know this, just an FYI.
-J
For the original question about updated jackshaft fix....i no longer use any close to what Vortech said would work. Mine is a HIGH RPM U-Joint and it also withstands HIGH TEMPs. I can dig up my reciept and get whomever needs one the part number but ive gotten about 800+miles on my setup so far and works great.
