Thanks for that.
Just been reading the NSK site and it says this bearing should have good lubrication !!
NSK 6205DU  (25 x 52 x 15 )
NSK 6205DU The Application And Maintenance
NSK bearings is the first bearing Trademark in Japan, it is regarded as the "mechanical industry food".NSK 6205DU advantage is it's pure material and high precision, widely used in different environment and machinery, such as automobile industry, electric motors, gear device, injection molding machine, machine tool, mining machinery, construction machinery, motorcycle, office equipment, paper machine, pumps and compressors, railway field, semiconductor field, metallurgical equipment, wind power generator and so on.
 In order to keep NSK 6205DU high-performance, we should put it in a clean space with good lubrication, When we check NSK 6205DU, we'd better to clean the surface at first, then remove the peripheral parts. Do not put excessive force when we check and disassembling bearings, in case of the damage of the parts. If the bearing oil seal and its surrounding parts has appeared the adverse symptoms, please replace it, so as not to the bad oil seal damaged the bearing.
maybe running this bearing dry, limits its life ..... G.
