Vibration at 3k in all gears
PHilly
Sussex, WI (Illinois is beneath us)
Hey guys,
Weird thing. I just got this car about 3 weeks ago. As I come up to 3,ooo rpms the shifter vibrates heavy. I can feel in "build up" as I aproach 2,500 rpm's and then It goes away at about 3,500 to 4,000. This happens in every gear. I first thought it could be the tranny mounts, but I'm not sure since it goes away and doesn't even return at high rpms. Any help?
-Jon
so its only in the shifter?
if it were my car, I would pull the shift tower and inspect the shift tower bolts to see if there is any sheering going on.
Sorry if this is a dumb question, but how do I inspect the motor mounts? Will there be noticable wear if they need to be replaced?
You need to get under the car to check. The rear is nice and low fairly easy to check, the front located about 10" up. Look to see the condition of the inserts. Check this thread
