montrese04
I suggest drilling out the old threads, and re-tap for a larger bolt. You should probably use a M10x1.5 tap and bolt. Use a 11/32" drill bit to drill out the stripped threads before using the M10 tap.
that would probably cost just as much as the helicoil:shrug:. tho my basement is practically a warehouse of tools. so i'm quite sure i MIGHT have a drill and tap that size already. but you know when you search for one specific thing when you really need it. That it's never there:nonono:. Also any idea where i might get a bolt that size that's already the same or near length
