blu_fuz
New Member Classroom vulture
If you are planning on any power adders or a 3L swap, do not use the LUK clutch. I just got off the phone with LUK regarding their 07-137 clutch kits and the issues with them. They said if the car is not 100% stock, do not use their clutch kit. They will not be changing the failure points that we are experiencing. I told them that even some 3L swaps are only 20hp and 20tq over stock dyno numbers and he simply stated "it isn't designed for that much power increase" and that we are "abusing our cars, because of course they are a SVT".....
I also said that most every Contour/Cougar/Mystique owner is opting to use the 3L engine because it is cheaper to replace than the 2.5L and increases power. If LUK didn't fix or address these issues, then they will be pushed out of the market for this platform because eventually most everyone will have a 3L and/or some kind of power adder.
He just told me to use an aftermarket upgraded clutch kit.
Also said that the 1995-97 Contour's were the worst cars ever. Laughed after I told him mine was a 1995 and pushed the fact again that if I saw what he saw or knew what he knew, I would think the same. He used to work for Ford putting these cars together. He currently drives a 4cyl MTX post 98 Mystique. And, he is helping a buddy of his do a 3L swap on a SVT Contour. He comes off as a "let me talk, and you listen" kind of guy. Didn't really care what I had to say and had an excuse for everything I asked about. :shrug:
Here is the email I sent them, and the rest was phone conversation.
"An acquaintance of mine contacted you about the center spline of the clutch disc "letting go" on the SVT Ford Contour clutch kits 07-137. I tried calling your company and didn't get to talk to anyone about the issues, but I'm happy to see he got an email response and you seem to be knowledgeable on the platform.
I am a victim of this clutch failure. I'm not looking for compensation, I would like this information to be used to make your product better so we don't have to "drive on eggshells" hoping that the clutches stay together.
I installed your clutch kit with the pressure plate, throw out bearing, and clutch disc. These were brand new, in a Ford box, with Ford part numbers etched on it, and the LUK stamp on them as well. I figured getting the OEM FORD new old stock would be the safest way to go since people were having issues with the LUK Repset clutch discs. Noted problems were the center spline ripping loose from the clutch disc, and also the spring windows stretching open enough for the springs to pop out and tumble around in the transmission case. Most people are only getting 10-20,000 miles from the LUK Repset clutch kits.
Here are the pictures of the kit that failed:
http://i49.photobucket.com/albums/f253/blu_fuz/For Sale/2-23-2011027.jpg
http://i49.photobucket.com/albums/f253/blu_fuz/1995 Contour SE 3L Build/newpics023.jpg
http://i49.photobucket.com/albums/f253/blu_fuz/1995 Contour SE 3L Build/newpics022.jpg
After only about 25,000 miles the spline ripped from the clutch disc under normal driving. I was up to about 30-35mph in 3rd gear and pushed on the gas while already in 3rd to get up to traffic speed. Accelerated like normal for a few seconds, then the RPMs shot up and I lost all clutch. Then all I got is a scraping noise with the clutch pedal let out. Pushed in it's quiet. There was very little wear on the clutch disc friction material. In the 2nd video you can see the pieces of plastic that I had in my hand, these were laying in the transmission case when I opened it up.
Here is the video of the clutch noise minutes after failure:
http://www.youtube.com/watch?v=-YB3bpDSrF0&feature=g-upl
Here is the video of the clutch disc damage to the spline after I removed the clutch:
http://www.youtube.com/watch?v=M_tAp92qvXs&feature=g-upl
I still have this clutch disc that failed in my car, and I have another disc pulled from another car that was installed at the factory with unknown miles that shows signs of the spring windows opening up and the loose springs. I can mail these to you if it helps your company figure out what is going on.
Thanks for reading, hopefully we can figure this out. Thank you!
"The Clutch kit uses the same parts as the OE. I went through all of our calls and warranty claims for Kit 07-137 which fits your vehicle. I have not had one concern for which you are stating. When a center of the disc comes apart many times it’s the front bearing inside of the trans or dowel pins between the block and trans are missing or damaged. If you like feel free to call me.
Thank you
Brian Smith
Schaeffler Group USA
5370 Wegman Dr.
Valley City, OH 44280"
Thank you
Brian Smith
5370 Wegman Dr.
