Lord Stanley
ASSuming a little much, huh?
Hey, whenever you assume you make an arse out of u and me... Something my Senior Seminar teacher taught us :laugh:
... WELL I CALLED FORD AND THEY SAID THEY USED SOMETHIN CALLED A "BLACKBOX" TO CHECK MY WIRING HARNESS. HE SAID IT SENDS A VOLTAGE THROUGH THE WIRING HARNESS AND CHECKS IT FOR PROBLEMS. HE SAID THEY CHECKED ALL THE WIRING HARNESSES BECAUSE THERES MORE THEN ONE(WHICH I ALREADY KNEW) AND HE SAID THATS HOW THEY FOUND THE 2 BROKEN MAF WIRES....
Most probably.we will be putting down the hammer on ford. i went to a different garage to get some codes checked and wow what do you know...4 codes.
P1000-OBDII system check incomplete
P0603-internal control module.
P1127-downstrean o2 sensor not tested
P1780-transmission control switch out of range
since ALL that stuff was replaced already why would it still be giving codes? the only thing i can think of is the wiring harness. .
