RialKnight
Last week I pulled this code from my car's PCM----P0715 Turbine Shaft Speed Sensor circuit fault.
After replacing the TSS, I thought everything was ok, nope.....after 3 days the error code came back...so, thinking the one I got was bad...I replaced it........did it fix matters.....nope, not at all........I still have the same code--P0715 Turbine Shaft Speed Sensor circuit fault......& yes I've reset the PCM
what's the lowndown of this part?
