elraido
I kant speel
Your cable most likely stretched or is bound up like mine.
so is it fine to use the ones for use with a spoiler on a car without one?
and yeah, my key doesnt work in mine either, but the drivers latch and the remote work just fine, maybe this became a problem and the locks "froze" after not much use.
only pre98 have a seperate trunk key. 98 + cars its only one key, unless someone changed the locks.
hmmm... i learnt on here a while ago that a different key opens the trunk. there were too many ppl who couldnt open their trunks with the keys. no way we all had the locks changed. so u're saying they all just froze? i've got the same issue. my remote doesnt pop the trunklid, neither does my key. only the release lever by the driver's seat works. even then, i'd have to pull it more than once.
This exact thing happened to me. I took a rod, and fit it between the middle arm rest on the back seat, you should have a little space to see the trunk. I took the rod, popped my seat realease, crawled into the trunk and flipped the red switch over. But then again the switch was my problem, don't know if its yours.
well i had some time today and im in the trunk... i flipped the switch and the keyless still wont work... can i get in there and manually unlatch it somehow?
i unbolted the latch....
it just came up somehow... im gonna go to the junkyard next weekend and get a new latch i think..
Did the cable attachments look ok? That would have been my first guess as to the source of the problem
